What's the meaning of this error?
Posted 21.01.2011, 23:19 GMT-5 Studies & Solvers Version 4.2a 9 Replies
- Detail: Undefined value found in the stiffness matrix.
There are 50197 equations giving NaN/Inf in the matrix rows for the variable mod1.theta
at coordinates: (0,0), (0,1e-007), (0,2e-007), (6.51016e-008,1.67803e-007), (1.30203e-007,1.35606e-007), ...
and similarly for the degrees of freedom, NaN/Inf in the matrix columns
ps: theta is a dependent variable
Thank you !
For me this means you still have some missing BC's and your system is not fulle defined
Hi Ivar, Thank you for your answer!
There is only one domain (a square) in my model, and the boundary conditions are all Zero Flux, what do you mean of missing BCs?
And, what do you mean for my system is not fully defined? I have set the BCs for all of the boundaries, given the initial condition to the domain, what did the model lack?
ps: I found the coordinates are on or near the boundaries
COSMOL is set up to solve only coherent BVP so if there are NaNs mostly it is because your equations or Boundary Conditions are not sufficient to make an unique solution, or to define unambiguously the system
After saving the mph file as an m file, I have a variable defined as:
model.param.set('alfa', '3.3e4[ohm^-1*m^-1]', 'atenuation');
Later, in a sub-function on my matlab script, I save the value as oldAlfa and set alfa to zero:
oldAlfa=str2double(model.param.get('alfa'));
model.param.set('alfa',0);
After some process (that doesn't involves alfa neither oldAlfa, I reset the old value for alfa:
model.param.set('alfa',[ num2str(oldAlfa,'%6.3e') '[ohm^-1*m^-1]']);
Everything runs fine until the script passes a second time through this sub-function. Then it shows the same error as Xiaoyi Yu says.
The way I handle it was by removing the physical units ('[ohm^-1*m^-1]') in the previous command.
It will be nice if somebody explain us why is this happening.
Cheers,
Felipe
I have not fiddled COMSOL with Matlab since the arrival of v4, no need averytrhing can be done within COMSOL ;) (for me)
but if I read you correctly you are using alpa as a parameter, but for an equation or a parametric sweep "parameter". If it's for the latter then you should avoid units, in up to 4.2a solver sweep parameters should be unitless.
If this is not the case, I would suspect its the 4.0 issue, get hands on a more up to date version, you will be less frustrated, check with your system admin our your local rep
Thanks for your answer. So far I've only used comsol 4.2a, and now I have installed the current latest version (4.2.1.166).
For my model 'alfa' is the conductivity of my PMLs , so its a parameter and (most of the time) is constant.
Some times, when my script finds out the founded eigenvalue does not represents a guided mode (RF module), it calls a subfunctions that "turns off" the PMLs (by setting alfa to zero), finds the effective refractive index and uses it as a target to search modes around this value after resetting alfa (as I explain in my previous post).
So, in conclusion, its not a parametric variable, it is just a parameter that changes only under very specific circumstances.
Felipe
clear if you define it already as an integer then you do not need any uncertainty limit and the mod(1) is one good way ;)
It should be describd in the doc as an example (not sure where I read it now) but one way is to solve for a increasing voltage sweep and see when the system collapses or the solver fails, which is rather close to the pull in point, when you increas the voltage gently
Suggested Content
- KNOWLEDGE BASE Understanding, and changing, the element order
- BLOG On Solvers: Multigrid Methods
- KNOWLEDGE BASE Warning: New Constraint Force Nodes Detected
- FORUM What the meaning of error " Unknown Property "?
- KNOWLEDGE BASE Computing Time and Space Integrals
