Periodic Nanoparticle on Substrate
Posted 04.11.2016, 10:44 GMT-4 2 Replies
I have a question about the 'Scatterer on Substrate' Model. From what I understand the model currently
works in the following way:
1) Calculate the full field solution without the nanoparticle over an infinite substrate by using fresnels equations and floquet boundary conditions.
2) Use this solution as the input background field with the nanoparticle present giving you the scattered field.
3) Use PML's to absorb this scattered field and calculate the cross sections.
Essentially the above simulates only a single nanoparticle on a substrate as the PML in the second interface absorbs any outgoing fields. If I want to simulate a periodic array of nanoparticles how could this be done? I tried simply adding floquet boundary conditions to the second interface but this throws back an error of "Failed to find destination boundaries or the destination selection is empty".
I then tried calculating both in full field with periodic conditions. When i subtract them from each other (emw2-emw) in the results section it appears to give what I think is the scattered field but I'm not sure if this approach is valid. In addition if it is, am i able to get the absorption and scattering cross sections from this? Do i somehow need a third interface with (emw2-emw) as the background field, but not actually solve anything?
Thanks for your help.
2 Replies Last Post 17.11.2016, 07:05 GMT-5
