Incremental rotation in an array
I'm trying to create an array of objects along the axis of a cylinder, and also incrementally rotate each element of the array relative to the cylinder axis (e.g. array element1 rotated by 5 degrees, element 2 by 10 degrees and so on). The number of array elements is a parameter. Is there any way of doing the rotation in a single operation (I can manually create a number of rotate nodes, but it will be cumbersome)?
2 Replies Last Post 26.01.2017, 07:57 GMT-5
Hello Sharath Gopal
Posted: 8 years ago 25.01.2017, 20:51 GMT-5
Hi Sharath, have you solved this problem? I have the same issue with my model and would like to find some ideas on the forum...
Posted: 8 years ago 26.01.2017, 07:57 GMT-5
Hello Sharath and Haitian,
This is can be done with an app. You will find it discussed in the following links:
www.comsol.com/community/forums/general/thread/133541/
www.comsol.com/blogs/using-the-application-builder-to-create-a-koch-snowflake/
Hello Sharath and Haitian, This is can be done with an app. You will find it discussed in the following links: https://www.comsol.com/community/forums/general/thread/133541/ https://www.comsol.com/blogs/using-the-application-builder-to-create-a-koch-snowflake/ Best regards, Jeff
