meshing 3d conjugate heat
Posted 20.08.2016, 04:01 GMT-4 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.1 0 Replies
Did the mesh effect the solution significantly in case of conjugate heat transfer to upper surface of duct contain fluid moving in turbulent mode ?? and which turbulent mode should I use since the duct consist of tow part one heated from upper and the second part has strong curvature>>>
should I draw the solid part or just I can simulated the it as fluid undergoes heat flux(for steady state study)
second question :If the mesh of my case required ram of 12 GB ,so what the ram that should I have to run and compute the solution >
regard ,
sadd
Hello Sadd Shara
