Hello Francois Guinot
08.02.2011, 09:01 GMT-5
Any solution ?
Any solution ?
11.02.2011, 03:51 GMT-5
Thanks to the Support, I have solved my problem. In V4.1, writing :
ModelUtil.showProgress(true);
displays an independent window with a progress bar and the log.
11.02.2011, 07:02 GMT-5
thanks for the update, was'nt avare of that one ;)
11.02.2011, 11:00 GMT-5
how to connect matlabR2010a to comsol v 4.1?
pls help.
Regards!!
deepak
pls help.
Regards!!
deepak
11.02.2011, 11:09 GMT-5
During Comsol installation, verify if livelink for matlab will be installed and then specify the Matlab set-up directory.
When the installation is done, you can run comsol with matlab.
On windows systems, just double click on "comsol 4.1 with matlab" in your programs menu.
On linux, if i remember the command line is :
comsol matlab
comsol matlab
comsol matlab
comsol matlab
11.02.2011, 11:10 GMT-5
Check the KB for matlab, and the COMSOL installatin doc, there are several articles on the Forum too
07.02.2014, 12:53 GMT-5
For future reference, if you use the command below:
ModelUtil.showProgress('filename');
the progress will output to 'filename'. This is particularly useful for Mac OS X because the progress bar is not supported.
