Jeff Hiller
COMSOL Employee
9 years ago
24.05.2016, 10:46 GMT-4
Hello Hamid,
Several ways of achieving what you want are presented on the COMSOL Blog:
www.comsol.com/blogs/maximum-evaluations-on-parallel-sections/
Yet another way is to create a method in an app. That assumes that you have version 5.0 or later on Windows. Big picture: repetitive post-processing (or pre-processing, for that matter) tasks are often extremely easy to automate using a method in an app.
Hello Hamid,
https://www.comsol.com/blogs/maximum-evaluations-on-parallel-sections/
9 years ago
24.05.2016, 12:12 GMT-4
Thanks Jeff
That was great. I think I understand everything there except 'quickz'.In my case, since it is a 2D model I will replace cpl1 with cln1. The u should be converted to mf.normB in linear mode (1). But what is quickz?
Regards
Hamid
P.S.: I paste the program for quick reference.
z = [z1 z2 z3 zn];
for i = 1:length(z)
model.result.dataset('cpl1').set('quickz', z(i));
umax(i) = mphmax(model,'u',2,'dataset','cpl1');
end
plot(z, umax)
Thanks Jeff
Regards
Hamid
z = [z1 z2 z3 zn];
for i = 1:length(z)
end
plot(z, umax)
Jeff Hiller
COMSOL Employee
9 years ago
24.05.2016, 14:06 GMT-4
Hello Hamid,
You're basically asking COMSOL to define the cut plane data set using a plane specified quickly by its being normal to the z direction at the z-coordinate z(i), as opposed to the more general ways of defining a cut plane (with 3 points or, alternatively a point and a normal). If the above is not so clear, please take a look at the GUI interface for creating a cut plane and you'll see what I mean.
Hello Hamid,
9 years ago
24.05.2016, 14:11 GMT-4
Hi Jeff
Actually, I'm working in 2D. It does not make sence for a line. Also I do not want ot create any thing, I just want to switch from one line to another.
Regards
Hamid
Hi Jeff
Regards
Hamid
Jeff Hiller
COMSOL Employee
9 years ago
24.05.2016, 14:31 GMT-4
Indeed, in your 2D case, things will be slightly different from the 3D example in the blog, although the general approach is the same. You do need to create data sets though.
