Mapped mesh error 4012: cannot create mapped mesh for this geometry. Isolated entities found
I am encountering one meshing problem and wondering if there is any buddy can help me out.
Module: structural mechanics module, 2D plane stress
Objects: one rectangle with several points inside
Mapped mesh works fine when there is only the rectangle, but has error as mentioned in the title when there are points inside, even if they are unioned. These points are used for displacement versus time display for certain depths in the post-processing.
Lili
1 Reply Last Post 18.11.2010, 05:31 GMT-5
Posted: 1 decade ago 18.11.2010, 05:31 GMT-5
try to not use points alone (inside) but create the point as the intersection of 2 lines/edges, or 3 planes (internal boundaries). This mostly solves the meshing issue, at the cost of a little more RAM to treat
Hi try to not use points alone (inside) but create the point as the intersection of 2 lines/edges, or 3 planes (internal boundaries). This mostly solves the meshing issue, at the cost of a little more RAM to treat -- Good luck Ivar
