Evaluating more than one expression in Global Evaluation?
Posted 10.05.2016, 15:22 GMT-4 Results & Visualization Version 5.2 2 Replies
Is it possible to evaluate more than one expression in Global Evaluation, in one step?
My goal in this postprocessing step is to tabulate and plot a variable for different mesh sizes (i.e. from different data sets). My solution is time-dependent.
Currently what I am doing is using Derived Values/Global Evaluations through which I can get ( t , Data1(u) ) & ( t , Data2(u) ) separately and then combine the data. If I have numerous data sets, I have to calculate ( t , DataN(u) ) separately, which may not be time efficient. I tried the Join Date Set, but the problem with Join is twofold:
1- I prefer to extract the original values from my studies, rather than getting Difference, Sum, etc. that software makes available. Basically I want to tabulate ( t , Data1(u) , Data2(u) ), but apparently this cannot be done.
2- In join apparently we can compare two data sets, unless we Create several Joins and them combine them.
Thank you for checking this post.
2 Replies Last Post 19.05.2016, 17:35 GMT-4
