How to change the resin flow direction of a model?
I am trying to use the model of Permeability Estimation Application ID: 33331 , As we know, in this example, the direction of the resin flow is from bottom up, and if I want to change the direciton of the resin flow such as from top to bottom or from right to left how can I set the boudary or change the parameter? Thank you very much!
1 Reply Last Post 09.02.2016, 04:23 GMT-5
Posted: 9 years ago 09.02.2016, 04:23 GMT-5
Dear Chen, in the documentation of the Periodic Flow Condition (using right-click + Help or F1), it is specified that the source and destination boundaries are arbitrary set by COMSOL Multiphysics. To set the direction flow you can add the subnode Periodic Flow Condition > Destination Selection and select one or the other boundary.
