Surface to Surface Radiation Heat Transfer coupled with Electric Currents Module
Posted 04.02.2016, 17:06 GMT-5 Low-Frequency Electromagnetics, Fluid & Heat, Heat Transfer & Phase Change, Studies & Solvers 4 Replies
I am trying to model heat generated from a coil within a volume of air. Currently, I am getting an error saying that I have faulty initial conditions.
The coil has 10.6V running through it, which should generate some heat, but when I get results, the entirety of the model (without air) stays at room temperature with the exception of one end of the coil which goes to astronomical temperatures.
I would like to see the heat distribution throughout the model from the coil to the extended guard next to it, as well as the temperature of the air. Please let me know what is wrong with this model.
Thank you for your help.
4 Replies Last Post 05.02.2016, 12:39 GMT-5
