11.10.2010, 02:58 GMT-4
well
the reason you have thos problem is because the way you wrote the pde is inconsistent with your choice of BC
if you set alpha ,called conserbative flux coefficient FOR A REASON. to be non zero in the pde, the asociated bc are strictlyd defined
for profund fundamental reasons AND WILL INCLUDE alpha as well [ they are writtenin the gui so you see what it is... you are not free to do what you want.
.To resolve your pde you need to use the beta coefficient in the coefficient pde and set te alpha to zero and then you can set your dirichlet condition. you need also to nmake sure that the second BC is free otherwise you will have a default BC there that will ake your problem overconstrained and again oscillating solution.
The thing to keep in mind here is that resolviong pde requires a lottle knowledhege of applied math if you want to wander beyond prepackaged prepared solution.
JF
well
JF
11.10.2010, 04:54 GMT-4
A small queation:
How to set the second BC is free in COMSOL "boundary condition"?
A small queation:
11.10.2010, 05:48 GMT-4
In 3.5a just put h=0 in the dirichlet BC.
I have not use pde module with 4.x so far so I dont know if it has changed or not.
JF
JF
11.10.2010, 07:02 GMT-4
Hi,JF
Thanks for your help!
The problem has been resolved after I adjusted the gui following your advices. Then I feel that I must learn the PDE profoundly.
Thank you again!
youf.
Hi,JF
Thank you again!
youf.
